Here is the problem, if I install RTX under programfiles (x86) folder(which is the default option on 64 bit OS) and then install my plug-in application, everything is ok. But if I install RTX to other directories such as C:\Program Files and then install my plug-in application, I find this in my MSI log "WIN64DUALFOLDERS: 'C:\Program Files (x86)\' will substitute 17 characters in 'C:\Program Files\Tencent\RTXC\' folder path. (mask argument = 0, the folder pair's iSwapAttrib member = 0)."
It seems somehow MSI changed the actual path find by the system search and therefore install my files to the wrong directory, which makes my plug-in fails to load, can I prevent this, any ideas are appreciated
Edited by kenzo22, 31 August 2010 - 04:15.
