I realize that there is a probem with the disk space dialog for Installshield Professional 6.
SdDiskSpace(svDisk, szTemp, szRequireSize, bChange);
the szReqiureSize is only shown correctly for the deafult system drive C:
If I select other Drives, the Required Space Size always shows 0 instead of szRequireSize.
Does anyone know will there be any fix for this or that is a funtion as designed.
Thanks!
Disk space dialog (SdDiskSpace) problem
gaolifeng
, Jan 07 2005 16:18
Posted 08 January 2005 - 02:33
I don't see that dialog in the IS Professional 6.31 help file or even the dialog sampler, so where did you get it?
Posted 10 January 2005 - 20:28
It is an internal function, you find its declaration in the SDINT.h file.
Posted 10 January 2005 - 22:06
Okay, so in that case, why you using an internal function instead of a standard dialog/fucntion?
Posted 11 January 2005 - 16:54
I am using that dialog as part of a custom Destination dialog, user can always check what is disk space on other drives.
But this internal fucntion seemed has a bug on it.
Does anyone know where I can file a bug report for installshield programs?
Posted 12 January 2005 - 04:17
Hmm, well I wouldn't expect to get a patch for IS6 due to its age and since it already may be resolved in a new version of the product, but there's probably something on the InstallShield website for filing a bug report.
However, you can try updating to version 6.31 if you haven't done so already.
