I'm completely new to install shield.
Can anyone suggest me how to create a single installer that can work for 32 bit /64 bit machines.
I have to make some registry entries and some dependencies of the project are platform architecture specific. So same installer doesn;t work on different platforms.
Single installer for 32 bit and 64 bit machines
nav_umm
, Dec 20 2011 02:40
Posted 20 December 2011 - 15:53
That's certainly doable with an InstallScript project by conditionalizing things accordingly, but unfortunately given your lack of experience, it's not something I can sufficiently cover in forum posting. I'm also not sure how you should best build up that knowledge other than enrolling in Flexera Software's "InstallShield, InstallScript" training classes.
To gather some additional information though, exactly what version of InstallShield are you using? Also, is this a 32-bit product that is meant to support both 32-bit & 64-bit Oses -or- will you have separate 32-bit & 64-bit binaries for each OS?
Posted 22 December 2011 - 07:57
| QUOTE (Taco Bell @ 2011-12-20 15:53) |
| That's certainly doable with an InstallScript project by conditionalizing things accordingly, but unfortunately given your lack of experience, it's not something I can sufficiently cover in forum posting. I'm also not sure how you should best build up that knowledge other than enrolling in Flexera Software's "InstallShield, InstallScript" training classes. To gather some additional information though, exactly what version of InstallShield are you using? Also, is this a 32-bit product that is meant to support both 32-bit & 64-bit Oses -or- will you have separate 32-bit & 64-bit binaries for each OS? |
Thanks for the response.
I'm using InstallShield 12.
I have some common binaries but there are some uncommon binaries also for each OS. And there are some third party dlls which are different for 32-bit and 64-bit.
Edited by nav_umm, 22 December 2011 - 07:59.
