It is possible to bypass the user's permissions (elevated privilege) using a tool such Group Policy.
Currently I use the install condition "AdminUser" so the setup won't continue when the user hasn't admin rights. Ok but I'm asking if the condition "AdminUser" is ok when the setup is launched using a tool such Group Policy? I want to allow the use of a such tool and I heard that only the execute sequence service is granted...
Thank you!
Elevated Privileges
lavocat
, Aug 17 2005 15:18
Posted 17 August 2005 - 15:47
And what about the "privileged" property condition ?
Is it less secure than AdminUser ?
Thanks !
Thanks !
Posted 18 August 2005 - 21:32
[AdminUser] is not set when the install is run with elevated rights.
[Priviliged] (btw starts with a capital P) means that either [AdminUser] is true, or the install is running with elevated rights.
An install with elevated rights means that the execute sequence is run using the account of the Windows Installer service, instead of the account of the active user. Usually this is the SYSTEM account.
Posted 19 August 2005 - 13:30
It's clear now
So I should use [Priviligied] instead of [AdminUser] as install condition of my basic msi project?
Edited by lavocat, 19 August 2005 - 13:30.
