Anyone know how to make an MSI that installs itself to the Default User profile so that any new user automatically gets the cusotmisation included in the MSI. I can make it install to both the current user and all existing users but not to the default user.
Any help would be great
Cheers
MSI that modeifies Default User Profile
ca001560
, Jun 16 2003 17:03
Posted 21 June 2003 - 12:23
The default user profile is not loaded in the registry, so you would need a custom action to do the following:
1. Load the default user profile (it's the NTUSER.DAT file in the .default profile folder) - I normally place it in a TEMP key under HKCU, but the choice is yours.
2. Edit the default user profile according to your needs - you will need to modify the registry paths to include the TEMP key under which you placed the default profile.
3. Unload the default user profile
I've done this in the past using Winbatch to manipulate the registry and fix up the .REG file to accomodate the modified path.
EdT
EdT
ERT
