I am using Wise 4.21 on XP SP2
When I click on the browse dialog I get Internal Error 2343, which means "Specified path is empty." Looking in the debugger I can see the _BrowseProperty is set to the correct directory. What is going on?
Browse dialog gets Internal Error 2343
RobCrockett
, Nov 01 2005 23:03
Posted 02 November 2005 - 11:24
_BrowseProperty is set to a directory path (C:\foo\bar) or to the name of a property in the Directory table? The latter should be the case, and this property should have a valid default value.
