I am experimenting with COM extractiont through component wizard. All works fine and dlls are properly registered. I have just one question- at one location in registry -
HKCR\Typelibs\0\Win32 i have got a value set to [!mydll.dll]. What does this signify. I suppose it gives the location of a file on target machine, but I am not sure as at some time I have also come across [#myFile].
Just for info, apart from this I have also come across following :
[$myComponent] - installation location of component 'myComponent'
COM extract through component wizard
varunAdb
, Apr 26 2011 07:17
Posted 27 April 2011 - 03:53
These are formatted strings that are resolved during installation to path values. From the Windows Installer SDK:
"...if a substring of the form [#filekey] is found, it is replaced by the full path of the file, with the value filekey used as a key into the File table."
"...if a substring of the form [!filekey] is found, it is replaced by the full short path of the file, with the value filekey used as a key into the File table."
More details: http://msdn.microsof...9(v=VS.85).aspx
Edited by Glytzhkof, 27 April 2011 - 03:54.
