How can I to check, if Windows Installer 2.0 is installed..
Thanks for any replay.
WindowsInstaller 2.0 is installed checking
Yehuda
, Sep 11 2002 15:35
Posted 11 September 2002 - 18:19
you can check the file version, md5 hash, or such on the file binaries stored on the target system... ( i have a complete list of the install file particulars for v1 -> v2 if you want them )...
i believe that the schema field in the summary info uses the 110, 120, 200,... to specify the minimum MSI requirement for the product....
hope it helps....
hope it helps....
