Is there any way to allow users to specify folder path to each folder created in application folder? For example, in SQL2000 installation, users are able to install the program in C drive and assign a different path to database data.
Assign path to folders other than [TARGETDIR]
ClydeMontreal
, May 30 2003 17:11
Posted 01 June 2003 - 06:24
Try SetDirectory custom action to set the folder paths for directories already present/mapped in the target machine. You will need the property value from the Directory table of that correponding folder, and you can set the required folder path. (OR) Use the SetProperty to replace the paths with a newly created property which resolved the required path
Rajiv Madassery
Galway Scripting Center
Digital GlobalSoft Ltd.
(Subsidiary of Hewlett-Packard Company)
