I am using Installshield 2012 and my project type is basic MSI.
I have a feature which has got five components. all components have same destination path.
From system search i got the path required to install above 5 files. I need to set this path as destination for feature.
I tried to write property name i have got from system search in destination. But its not working.
Perhaps what is correct syntax for setting system search result property as destination path ?
Regards,
Amarjeet
Using system search to set dest. for feature
Amarjeet
, Jan 02 2012 10:52
Posted 04 January 2012 - 14:53
Use a custom action of type "set a property" to set the destination property of the components to the value of the system search property. Use the name of the serach property also as a condition to make sure the action is executed only if the search property isn't empty.
Insert this custom action in both, the InstallUI and the InstallExecute sequence, before CostInitialize.
