Hello,
Does anyone know where or when will be available a merge module to install the .NET Framework ?
I'm producing a web deployment project under VS.NET and the wizard creates automatically a dependency for a file with the name:
dotnetfxredist_x86_enu.msm
But I can't find it in Microsofts site.
_Merge Module for .NET Framework
caselli
, Mar 26 2002 19:27
Posted 27 March 2002 - 02:18
If you install the VisualStudio.Net, you will get this merge module. Unfortunately, it will not work. The "official" distribution is using dotnetfx.exe.
See: Detail on redistribution of the .Net Framework
Why? I have no idea! It's very frustrating to me. Has anyone out there done this? I can't use the default deployment because my CLR is conditional on someone selecting the feature that requires it. We don't want to bloat the users drive if not required.
Posted 30 March 2002 - 19:06
Yes.
After I posted this, I found the merge module and I also read the Microsoft article about the way to distribute the framework and the note about not beig possibile to redistribute the Framework merge module.
I decided to use the setup bootstrapper that installs dotnetfx.exe before executing my setup.
But it sure is a very ugly way to solve the problem.
I would much rather use the merge module.
They might rethink this. Let hope so.
Francisco Caselli[br]PHC
Posted 27 September 2002 - 04:39
I've actually had a bug using that bootstrapper setup with Windows ME. I get an error message after it installs the Framework and tries to suppress the reboot.
Does anyone know of a way to get around this? Perhaps we could make a merge module for dotnetfx but I doubt it.
