Hi everyone, using AdminStudio 3.5 and building an MSI for a network app. Need to know how to advertise a shortcut whose target is on a network drive. The target is an executable on the Q: drive (in our environment). I can create a shortcut to the .exe file, but need it advertised.
I try to select "advertised" when creating the shortcut, but then it defaults to the "ShortcutsComponent" component, which has no key file. If I select the executable as the key file, it adds the 1.1mb file to my package, which i don't want.
Any idea how I can advertise these shortcuts? Thanks.
Advertising shortcuts for network apps
Bryan_73
, Sep 09 2002 21:50
Posted 10 September 2002 - 11:42
I believe that Windows Installer can only created advertised shortcuts to files that are included in the install.
The official solution:
You could place your setup on the Q drive and run it from there. Select "run from source" option and the file will not be copied to the local machine, but accessed from the Q drive.
A hack:
Add a dummy file with that name to your setup, make sure the destination is the Q drive, and create an advertised shortcut to that file. Select "never overewrite" to make sure the dummy file won't overwrite the real file on Q.
A hack:
