- Through registry system search get value stored in registry key. I was successful and stored this property as [TEST]
- Created a new installshield dialog box and inserted edit field in the dialog. Gave same property name is above to this field i.e. test.
- In property manager set property name and value both to TEST.
I expect that when my dialog is presented to user the edit field is pre populated with the registry value installshield discovered during system search. But i get blank text in edit field.
Please let me what I am doing wrong.
Thanks in advance.
Amarjeet
Pre populate Edit Field with property value obtained from System Searc
Amarjeet
, Jul 06 2016 15:14
Posted 06 July 2016 - 15:14
Posted 11 July 2016 - 15:54
Note that "TEST" is not the same as "test". Use TEST as proeprtyx name in search and in the dialog.
