I wanted to hide the set-up progress dialog from the user during the roll back
I am rolling back the installation , during which my application launches Command prompt and the focus will be there on the command prompt. If i close the command prompt the installation is rolling back successfully, , but when I click on Cancel button of the Set-up progress dialog box , nothing happens .
Is there way to hide the Set-up progress dialog or move the focus from the command prompt to the Cancel button automatically( when the user does not enter any data on the Command prompt) , so that installation roll backs even after clicking on the Cancel
button
Best regards,
cheluvambike
Hide the dialog from Command prompt
Ambika
, Dec 14 2009 08:03
Posted 14 December 2009 - 09:57
Are you talking about Rollback or Uninstall?
You can remove the Cancel button by running your setup in Basic UI mode using the switch:
msiexec.exe /i your.msi /qb!
or if launching from setup.exe:
setup.exe /v"/qb!"
setup.exe /v"/qb!"
