Hi there,
I have an installaiton with a merge module that contains 2 user custom actions - "CreateShortcuts" and "RemoveShortcuts". On initial install the shortcuts are created.
However when I do a patch up to a newer version the "RemoveShortcuts" action is run at the start when shutting everything down, but then the "CreateShortcuts" action is not run after the new files have been copied and applied.
Any ideas?
Cheers
Mike
Patch not re-running a custom action
MikeyK65
, Aug 20 2003 14:17
Posted 21 August 2003 - 11:14
I assume this is a Minor Update (i.e. ProductCode didn't change). What are the conditions you have on these custom actions? What does the log file tell you?
