I have an application that places a System path variable of "C:\blah_24\lib32". When I install a new version of this application I want to change the variable to "C:\blah_25\lib32". If I choose append, an entire new line will just be added to the the path. If I choose replace, the whole path will be replace with the one new line. How can I make this change using the options provided in Admin Studio 9.5? Thanks for any help
Eniviroment Variable
leshon
, Jun 30 2010 12:31
Posted 02 July 2010 - 15:56
Uninstalling the previous version (i.e. major upgrade) is not an option? This would remove the previous entry.
There are no built-in string processing functions in Windows Installer so you probabaly should sue a System Search to read the existing entry, use a custom action to change the text value of the property, and write it back using Windows Installer's standard functionality.
Posted 06 July 2010 - 19:00
Here's what I did to fix the problem. I used a custom action to run the following vbs:
Set objWshShell = CreateObject("WScript.Shell")
Set objEnvironment = objWshShell.Environment("SYSTEM")
strOriginalString = "C:\blah\blah3"
strReplacementString = "C:\blah\blah4"
strPath = objEnvironment("PATH")
strPath = Replace(strPath,strOriginalString,strReplacementString)
objEnvironment.Item("PATH") = strPath
I messed around with the placement to finally get it to work but I'm all good now.
Posted 08 July 2010 - 09:19
If you modify the target system in a custom action you should also create actions for uninstall and rollback (in case the install fails). It would be better to only use a custom action to do the string processing and use the Environment table to let Windows Installer handle the actual system modification.
