Hello:
Can some one tell me..How would I suppress the "File in Use" dialog that pops up when the files that are cuurently used are being upgraded(I want them to be overwritten after reboot).
I want to use the "IGNORE" button as default all the time with our popping it up.
I can use ORCA if needed to mock with it.
Leo
File in Use Dialog
dcleous
, Sep 17 2003 12:38
6 replies to this topic
Posted 17 September 2003 - 14:33
I set the Control_Default to "ContinueButton" ..would this prevent the dialog to be popped every time.
I don't want this dialog to popup with /qb option too...
Thanks for all your help.
Leo
Leo
Posted 18 September 2003 - 09:23
Setting the default button will not prevent the dialog from showing.
If you don't want the dialog to be displayed, delete it from your setup.
Posted 30 September 2003 - 17:20
Even If I edlete all the reference to FilesInUse Dialog I still get to see this
Dialog popup...which I don't want to..
"The following applications should be closed..."
"Cancel" "Retry" "Ignore"
are we talking about the same dialog??
Thanks very much.
Thanks very much.
Posted 30 September 2003 - 17:29
I meant you should completely remove that dialog from the dialog table. However in the meantime I learnt that this will cause an error. It seems like there is currently no way to avoid this dialog.
Posted 21 October 2004 - 17:08
is there any way of disabling the "ignore" button on this dialog?
Don Tasanasanta[br]Configuration/Installation Eng
