I have a .mdb file that needs to be installed if the version of a host program is equal to 3.2, else ignore. I have tried setting the condition field in the Components field to ByPassRouteDB = 1, which is set up in a program call, after checking the version. I believe that I'm setting the variable correctly. Is there something obvious that I am missing? Thank you for your time.
Component Condition
Island28
, Mar 29 2004 20:39
Posted 30 March 2004 - 04:22
Try using all capitals for the condition, this will make the variable global.
Also, check to see that the property is actually being set correctly during the install by logging the install.
Posted 30 March 2004 - 08:55
Why not use a companion file?
