Help! Installer starts to install for customer then rolls back
Posted 08 November 2018 - 18:46
Posted 08 November 2018 - 20:53
11-8-2018[10:23:36 AM]: Extracting 'BetaMarker.dat' to C:\Users\FLETCH~1.GAR\AppData\Local\Temp\{B8B15E3F-FAC7-4236-AD31-9BC3CF0B7685}\BetaMarker.dat
11-8-2018[10:23:36 AM]: Extraction of 'BetaMarker.dat' failed
11-8-2018[10:23:36 AM]: Extracting 'EvalMarker.dat' to C:\Users\FLETCH~1.GAR\AppData\Local\Temp\{B8B15E3F-FAC7-4236-AD31-9BC3CF0B7685}\EvalMarker.dat
11-8-2018[10:23:36 AM]: Extraction of 'EvalMarker.dat' failed
11-8-2018[10:23:37 AM]: Upgrade check: checking product code {F13E205F-04B5-4990-B19E-EE8FFE7545D4}
11-8-2018[10:23:37 AM]: Extracting '' to C:\Users\FLETCH~1.GAR\AppData\Local\Temp\{B8B15E3F-FAC7-4236-AD31-9BC3CF0B7685}\
11-8-2018[10:23:37 AM]: Extraction of '' failed
Does anybody know what betamarker.dat and evalmarker.dat are? Why does it try to extract ''?
Thanks for any reply..Is anybody out there?
Posted 10 November 2018 - 03:02
- Have you tried to disable the anti-virus or the security suite on the computer in question?
- It could also be that the PC is malware infected and impossible to install on, or locked down in some unexpected fashion.
- Even more commonly the setup.exe is corrupted and should be re-downloaded.
- One exotic option is to try to install with a different admin account on the box in question (create new account if there is no such account). This is to avoid user profile corruption issues.
If I were to guess I would say the setup.exe is corrupted. Have them re-download first of all.
To create a log file see msifaq.com for more details (logging faq entry).
To find errors in the log file, search for "value 3" in the log file to find errors as explained by Rob Mensching (Wix & Orca author).
Posted 20 November 2018 - 15:25
"The installer was interrupted before..." is a generic error message that is displayed when your setup fails for any reason. So you need to find the actual error message. Logging as recommended by Stein is a good start.
BetaMarker.dat and EvalMarker.dat may just be red herrings.
