I'm using InstallShield 2011, to create an installer for our product. However I ran into an issue with setting up the proper INSTALLDIR per feature, here is what I'm trying to do.
I have the INSTALLDIR currently set to "ProgramFiles\MyCompany\ProductName" then each feature goes under it's own feature folder, so under the Setup Design I have the Destination set as follows:
Feature A: [INSTALLDIR]\Feature_A_Folder --> meaning "ProgramFiles\MyCompany\ProductName\Feature_A_Folder"
Feature B: [INSTALLDIR]\Feature_B_Folder --> meaning: ProgramFiles\MyCompany\ProductName\Feature_B_Folder"
HOWEVER, we need to remove the ProductName from the path, so What I want to change is that: when the user chooses to install Feature A, I want to set the [INSTALLDIR] to be set to "ProgramFiles\MyCompany\Feature_A_Folder"
And when they choose to install Feature B, I want the [INSTALLDIR] to be set to "ProgramFiles\MyCompany\ProductName\Feature_B_Folder".
With this, I can always maintain setting the Destination path for all the files to [INSTALLDIR] without having to worry about where that is.
Could you please help? Thank you in advance for your help
