Hi all
Version: InstallShield Developer 8.0
Type: InstallScript MSI Project
INSTALLDIR = "D:\MIB"
Step 1.
I made 3 Features as below:
FeatureA with Destination Folder: "D:\MIB\A" (Directory Identity = MIBA)
FeatureB with Destination Folder: "D:\MIB\B" (Directory Identity = MIBB)
FeatureC with Destination Folder: "D:\MIB\C" (Directory Identity = MIBC)
Step 2.
I apply FeatureDialog in the setup.uri
the code: as below
FeatureDialog with Destination Folder property
MIB426
, Nov 17 2003 11:12
Posted 17 November 2003 - 11:12
| // Include header files #include "ifx.h" function OnFirstUIBefore() number nResult,nSetupType; string szTitle, szMsg; string szFeatures, szTargetdir; string svDir; number nLevel; LIST listStartCopy; begin SHELL_OBJECT_FOLDER = @PRODUCT_NAME; Dlg_Start: // beginning of dialogs label Dlg_SdWelcome: szTitle = ""; szMsg = ""; nResult = SdWelcome( szTitle, szMsg ); if (nResult = BACK) goto Dlg_Start; Dlg_FeatureDialog: szTitle = ""; szMsg = ""; svDir = INSTALLDIR; szTitle = "Select Features"; szMsg = "Select the features you want to install on your computer."; nResult = FeatureDialog(szTitle, szMsg, svDir, ""); if(nResult = BACK) goto Dlg_SdWelcome; Dlg_SdStartCopy: szTitle = ""; szMsg = ""; listStartCopy = ListCreate( STRINGLIST ); //The following is an example of how to add a string(szName) to a list(listStartCopy). //eg. ListAddString(listStartCopy,szName,AFTER); nResult = SdStartCopy( szTitle, szMsg, listStartCopy ); ListDestroy(listStartCopy); if (nResult = BACK) goto Dlg_FeatureDialog; Enable(STATUSEX); return 0; end; function OnMaintUIBefore() NUMBER nResult, nType; STRING szTitle, szMsg, svDir, svResult, szCaption; begin Dlg_Start: Disable(BACKBUTTON); nType = SdWelcomeMaint(szTitle, szMsg, MODIFY); Enable(BACKBUTTON); if (nType = REMOVEALL) then svResult = SdLoadString(IFX_MAINTUI_MSG); szCaption = SdLoadString(IFX_ONMAINTUI_CAPTION); nResult = SprintfBox(MB_OKCANCEL,szCaption,"%s",svResult); if (nResult = IDCANCEL) goto Dlg_Start; endif; nResult = NEXT; Dlg_SdFeatureTree: if (nType = MODIFY) then szTitle = ""; szMsg = ""; nResult = SdFeatureTree(szTitle, szMsg, INSTALLDIR, "", 2); if (nResult = BACK) goto Dlg_Start; endif; switch(nType) case REMOVEALL: FeatureRemoveAll(); case REPAIR: FeatureReinstall(); endswitch; Enable(STATUSEX); end; |
Problem:
When I am in the end user mode. All the feature has Destination Folder to "D:\MIB". Is there anyway I can use destination property in the feature itself?
Such as FeatureA will show Destination Folder to D:\MIB\A, FeatureB will show Destination Folder to D:\MIB\B. Or I have to ceate my own customer dialog?
Thank you if u can help me on this.
MIB
Posted 17 November 2003 - 18:23
I don't think the standard dialogs in InstalLScript MSI can do this. You would have to create a custom dialog.
The standard featrue tree dialog in Basic MSI can do it though.
Posted 18 November 2003 - 02:47
Thank you for reply me.
I guess I have to make custom Dialog then.
Do u know is there sample code relates to my problem?
thanks
thanks
