1) has anyone tried to convert an IE6 script (setup) to the MultiPlatform version? If so, how well did that conversion process go? I could imagine it being ugly.
2) If #1 is not supported or is not recommended, I am trying to decide if we should plan on using seperate installations for each environment - IE 6.x or 7.x for Windows and something entirely different for Linux.
3) if seperate installations for each OS are best, should I use RPM or MultiPlatform installshield?
Since Linux is a relatively small market for us currently, I would lean toward using RPM files unless I can easily come up with a simple, straigtforward strategy to use a common installation setup for both target environments.
Thanks in advance to any ideas / comments / advice!
