How do I force selection of a particular Setup Type (Compact, Typical, Custom)? I want to always choose the Compact or Typical option, but when looking at the InstallScript code, I don't see where it's value is being used. If I remove all the Setup Types except Compact, will it always use the Compact Setup Type.
Raj
Setup Type Selection
rajkulkarni
, Mar 22 2004 23:57
Posted 23 March 2004 - 00:01
Use this command to force a choice of set-up type
ComponentSetupTypeSet (MEDIA, szSetupType);
If you wanted to make sure it always used the COMPACT version it would look like this:
szSetupType = "Compact"; //Make sure it matches exactly to the name
HTH
HTH
