I have got two features "FeatureA" and "FeatureB" to be installed.
If featureA is selected for install FeatureB should be deselected for installation. And same for FeatureB. So feature selection is mutually exclusive.
I would like to do this after SetupType dialog box. I can do it by saying "Remove" event but it still shows the feature de selected with red X mark.
i want to hide the feature as well. The only way is to set feature install level to zero. But i am unable to find any event which can set the install level for a feature to zero.
Any idea how i can set install level for a feature through events / script...any means programmatically.
Thanks in advance.
Amarjeet
Set install level for a feature
Amarjeet
, Mar 12 2011 07:35
Posted 14 March 2011 - 17:42
I don't think this is possible, and I don't understand why you would want to do this. I mean: if user selects Feature A you want to hide Feature B, so if they go back to the feature selection dialog they'll see only Feature A and are unable to change their selection?
Do you have other features, or do you need to "run from source" or "install on first use" options? If not, you don't need to show the feature tree dialog at all. Instead use a custom dialog with radio buttons and make the selection with AddLocal and Remove control events.
