ICE43ERRORComponent Component_1 has non-advertised shortcuts. It should use a registry key under HKCU as its KeyPath, not a file.
ICE57ERRORComponent 'Component_1' has both per-user and per-machine data with a per-machine KeyPath.
ICE64ERRORThe directory COMP1_STARTMENU is in the user profile but is not listed in the RemoveFile table.
This install adds nothing to the registry (and can't).
ALLUSERS=1
I only want 1 shortcut installed into the ALLUSERS profile. I don't want to use advertisement.
To me it seems that adding a row to the directory table having ProgramMenuFolder as the Directory_Parent is causing the problem. For some reason MSI thinks that this folder is a User folder, when it should be a Machine folder.
The install works properly, but I'd like to get rid of these errors. Any ideas?
