Is it possible to change shortcut properties on WinXP using Professional 6.31? Can it be done thru the IDE or script? Specifically, is it possible to add or remove the checkmark in the "Run this program in compatibility for:" box that is found on the Compatibility tab? If not possible in 6.31, what about versoin 7? Thanks!
WinXP Shortcut Properties
Chad
, Sep 06 2002 15:10
