change location from where compiler picks setup.inx file
Posted 31 August 2015 - 07:35
Posted 04 September 2015 - 14:59
You could try using the compile.exe command line options.
Posted 05 September 2015 - 08:27
Hi Stefan,
Thanks for the reply.
Actually, I intended to ask something else.
I want to know how can I provide a Custom path to build command for the SETUP.INX (not setup.rul) file, so that build READS the setup.inx file from some location other than default. I have already changed the destination location, where Compiler outputs setup.inx File.
Posted 25 September 2015 - 13:19
I'm not sure there's such an option. If there's nothing in the docs, you probably have to use the standard.
Posted 25 September 2015 - 13:43
Posted 30 September 2015 - 09:36
I guess you mean "script files" and I don't think you can change that. Why would you?
Posted 30 September 2015 - 09:47
Thanks for the correction.
I meant 'Script Files' Only.
Need to remove this space as our CM Process has a limitation that it cannot have a space in folder name.
Currently we are facing build issues in CM build process because of this space.
Is there any alternate.
Sukrit
