I am trying to install the msi silently and at a custom path for all users..
code is:msiexec /I setup_wiz.msi /q ALLUSERS="2" INSTALLDIR="C:\TEMP\" but for some reason it is not taking that up the path ,it is installing silently at default path.
Could kindly help...
MSIEXEC Command line
Francisjude
, Sep 17 2004 18:32
Posted 21 September 2004 - 04:39
You need to open the msi file and see if INSTALLDIR is actually pointing to a folder or not. The features and components might not be using INSTALLDIR, they might have another global directory that they use.
INSTALLDIR is install shield specific.
Posted 21 September 2004 - 11:31
some other tools use TARGETDIR instead of INSTALLDIR
