I want to open a HTML-file at the end of the installation and I think it is flexible if the HTML-Viewer is used which is actually installed on the PC. So I don´t want to define in the IS6 script that always the internet explorer is needed.
Is there a way to open a file which file type is already registered in windows?
If not how can I start the internet explorer automatically?
Ralf
Open a HTML-file?
Ralf
, Jan 16 2003 12:36
Posted 16 January 2003 - 14:44
Here's some sample code I use to launch the associated application for HTML files.
| Code Sample |
| function BrowserLaunchURL(URLSite) NUMBER nvType, nResult, nvSize; STRING szRegKey, sExplore; begin RegDBSetDefaultRoot(HKEY_CLASSES_ROOT); nvType = REGDB_STRING; szRegKey = "\\htmlfile\\shell\\open\\command"; RegDBGetKeyValueEx(szRegKey, "", nvType, sExplore, nvSize); // remove quotes //LongPathToQuote(sExplore, FALSE); //NOTE: COMMENTED OUT DUE TO PROBLEM UNDER NT4. // if quotes are still found ... get what's inside the quotes if ( StrFind(sExplore, "\"") = 0 ) then StrSub(sExplore, sExplore, StrFind (sExplore, "\"")+1, StrLength (sExplore)); StrSub(sExplore, sExplore, 0, StrFind (sExplore, "\"")); endif; Dbg("Browser = '"+sExplore+"'.", INFORMATION); Dbg("URL = '"+URLSite+"'.", INFORMATION); nResult = LaunchAppAndWait(sExplore, URLSite, WAIT); if ( nResult < 0 ) then Dbg("Unable to launch the default browser.", WARNING); endif; return nResult; end; |
Posted 23 January 2003 - 19:01
You can use the ShellExecute Windows API, as shown in the sample on this site.
