Recently I thought it might be useful for my project to replace the CustomSetUp dialog altogether with one I designed myself, to make things clearer to the end user. The stumbling block to implementing this (with a dialog of checkboxes, rather than the confusing mutilple options of the standard dialog) is with finding a way to change the selection states of the various features based on the user input.
There is an IS function FeatureSelectItem, but that is only available in Standard projects. How could I achieve the same effect in a basic MSI project?
Feature selection states
jonathan2002
, Sep 25 2002 15:43
Posted 16 June 2003 - 14:05
MsiSetFeatureStates is the function to use. Do read the documentation on this function thoroughly as one other function has to be executed before and as MsiSetFeatureStates can only be executed in a specific area of the sequence (I dunno it by heart).
I use this very extensively and set some 20 features using this function.
Greetings,
Frank Gales
Greetings,
Frank Gales
Posted 17 June 2003 - 05:14
Another idea that you can use is to use the condition table to set feature to a certain InstallLevel based on a property value.
You could provide radio buttons and set feature states according to these.
