In a few components I've added a registry key which taken from the property value.
This property has a default value, and I can change it during installation via dialog.
If I've changed this property via dialog and after installation I see that registry key was created according to a new value.
But in the log file of uninstall I see that InstallShield try to delete the default registry key and respectively does not delete registry key which was changed during installation.
So, the changed registry key is not saved in the data base as the destination directory in the property INSTALLDIR.
Edited by Gorsoun, 28 March 2007 - 15:09.
