When my setup install some Drivers the warning message "...
Has not passed Windows Logo testing to verify its compatibility with Windows XP"
appears. Is there a way to prevent it?
Driver installation and WinXp warning message
lavocat
, Oct 06 2003 15:50
8 replies to this topic
Posted 07 October 2003 - 00:26
I don't believe so since that's by design, so the only legitimate way to prevent that is to get your driver signed by MS.
Edited by Taco Bell, 07 October 2003 - 13:43.
Posted 07 October 2003 - 12:56
In the Windows registry you can define the reaction on installing not verified drivers:
go to
HKEY_CURRENT_USER\ Software\ Policies\ Microsoft\ Windows NT\ Driver Signing
set the REG_DWORD "BehaviorOnFailedVerify" to
0 for ignore
1 for warn the user
2 for block unsigned drivers
So maybe you just change this registry value while installing the drivers you need?
go to
0 for ignore
1 for warn the user
Gruß / regards
Thomas
Thomas
Posted 08 October 2003 - 09:10
Well, on WinGuides Network you see, that the trick should work, if you add this key ...
They say it works for Win2k/XP.
Maybe you set up a test machine and give it a try ...
The other way would involve driver signing by MS!
Gruß / regards
Thomas
Thomas
Posted 08 October 2003 - 13:58
Trust me, It doesn"t work at all. I won't test it again so if you don't trust me tests it by yourself!!! And if you say to me that this works with 50% of xp versions then where is the interst???
I've tested it on a fresh Windows XP Pro 2002. I've created exactely the same key with the same value then I reboot and it doesn't work(there is still a warning message). To be very sure I put 2 instead of 0 and the reaction was ok ->if I put 2 the warning is transformed into antother window which prevent to install the non signed driver.
Another suggestion?
Another suggestion?
Edited by lavocat, 09 March 2006 - 16:04.
Posted 17 November 2003 - 19:16
Try using the GUI instead:
"Control Panel\System\Hardware\Driver Signing"
Posted 21 January 2004 - 19:22
Setting the Registry key directly is not recommended, as this is a System Policy setting which should be set with either:
(1) the System Control Panel's "Driver Signing Options",
(2) the Local Security Policy Control Panel, or
(3) domain Group Policies
However, in my experience this setting doesn't really work. For a more detailed explanation with screen shots, see my post at http://www.ewall.org...yarticle93.html
So, not wanting to beat a dead horse, but my client is asking again... Anyone have any other solutions? Thanx...
Edited by ewwallace, 21 January 2004 - 19:23.
