I have a few custom actions that do a certain task which takes a very long time...
approximately around 0.5 minutes each.
The custom action is called in different parts of execute sequence.
Is it possible to put some text in the progress bar (Some thing like : Removing Files ..., Generating script for installation, etc).
Currently I call the Custom Action inside the execute sequence.
When I call CA, the progress bar will freeze for 0.5 minutes, which is confusing for user.
Can I add some text on the progress bar?
Sample of CA that I call: (CA is in VB Script)
'Looping while installing silent directX
Do While i <= 20000000
i = i + 1
Loop
dim FSO
set FSO = CreateObject("Scripting.FileSystemObject")
set fout = fso.CreateTextFile("c:\idle8.txt", true)
fout.WriteLine "INSIDE CUSTOM ACTION IDLE"
fout.WriteLine "PROPERTY DIRECTXINSTALL: " + PROPERTY("DIRECTXINSTALL")
Any suggestion is welcomed.
Edited by agustina_s, 09 March 2005 - 10:35.
