Hi all,
Does anyone know where the value of INSTALLDIR is kept?
I want to load it with the value of a property (which is a registry key value).
I tried putting the property name against GeneralInformation-project properties-Destinationfolder but to no avail.
Is it possible to do this?
Berni
How to Load INSTALLDIR dynamically
bernadettefearon
, Dec 12 2001 13:35
Posted 12 December 2001 - 16:23
INSTALLDIR is a key to the directory table. Directories are not quite the same as properties. If you want to set it use a Type 35 Custom Action or call MsiSetTargetPath.
Posted 12 December 2001 - 16:33
I should add there are lots of implications if you attempt to change the directory during an upgrade or are installing for another user so take care,
See Msi Documentation
Windows Installer
--Using Windows Installer
------How do I change the target location for a directory?.
Posted 14 December 2001 - 15:38
Thanks for your help Ian -
I got it going with the CA35,
Thanks again
Berni
Thanks again
Berni
