I am having some problems creating a simple registry key. I used RegDBCreateKeyEx and it returns 0. When I look at the registry, the key was not created.
Can anyone tell me what I am missin from my code to make this work?
Rage
if ( !Is(USER_ADMINISTRATOR , "") ) then
MessageBox ("You do not have administrator privileges, Contact an administrator to install this Application.", SEVERE );
abort;
endif;
szSiteCode = "AmbassadorTest";
RegDBSetDefaultRoot( HKEY_CURRENT_USER );
szRegPath = "HKEY_CURRENT_USER\\Software\\ODBC\\ODBC.INI";
szKey = szRegPath^szSiteCode+"DSN";
if (RegDBKeyExist(szKey) < 0) then
szKey = "SOFTWARE\\ODBC\\ODBC.INI"^szSiteCode+"DSN";
nResult = RegDBCreateKeyEx(szKey, "");
RegDBSetKeyValueEx( szKey, "Driver", REGDB_STRING, "C:\\orant\\BIN\\SQORA32.DLL", -1 );
RegDBSetKeyValueEx( szKey, "ServerName", REGDB_STRING, @ENROLL_ID, -1 );
RegDBSetKeyValueEx( szKey, "UserID", REGDB_STRING, @ENROLL_PSWD, -1 );
endif;
szKey = szRegPath^"ODBC Data Sources"^szSiteCode+"GESDB";
szKey = "SOFTWARE\\ODBC\\ODBC.INI"^szSiteCode+"GESDB";
nResult = RegDBCreateKeyEx(szKey, szClass);
endif;
problems with creating registry key
comicrage
, Sep 16 2004 21:07
Posted 17 September 2004 - 01:22
Drop the "HKEY_CURRENT_USER\\" portion from the path. 'cause you've already specificied that via the RegDBSetDefaultRoot call.
Also, you should know that RegDBSetKeyValueEx will automatically create the key if it doesn't already exist.
Edited by Taco Bell, 17 September 2004 - 01:31.
