I need to make msi packages from the command line, but I can't find out how to change the product version from the command line.
So right now I always have to open InstallShield Developer 8.0 sp2 just to change the product version and then run the NAnt script that checks out, builds and runns IsCmdBld.exe for the final msi package.
Simon G
Any way to update product version from commandline
Mr.G
, Nov 16 2004 18:08
Posted 16 November 2004 - 22:39
This can be done using the automation interface and a VBScript. Would this be an acceptable work around? (if so I will dig up some sample code).
Posted 17 November 2004 - 08:57
Oh yes indeed, no matter how, I just need to make it work.
I build the msi using the same computer as I develope the application. All workarounds are appreciated and accepted:)
Please dig some samples, thank you.
Simon G
Simon G
Posted 17 November 2004 - 22:51
I wanted to do something like this anyway, I went one step further and based the version number on the main program's version number (we never build an install without building a new version of the main executable)
So here it is, super-duper rough cause I just coded it.
| 'this is the project you will build Dim mstrProject: mstrProject = "d:\MyProject" 'and the component which has the executable to base the version on Dim ComponentVersionToUse: ComponentVersionToUse = "Program.exe" main Sub main() Dim lobjProj: Set lobjProj = CreateObject("ISWiAutomation.ISWiProject") lobjProj.OpenProject mstrProject Dim lobjComp For Each lobjComp In lobjProj.ISWiComponents 'see if it is the file whos version we want to use If (strComp(lobjComp.Name, ComponentVersionToUse, 1) = 0) Then lobjProj.ProductVersion = GetVersion(lobjComp.ISWiFiles(lobjComp.Keypath).FullPath, lobjComp.Name) if Len(lobjProj.ProductVersion) > 0 Then lobjProj.SaveProject() Else msgbox "Could not get the version to use" End IF Exit For End If Next lobjProj.CloseProject End Sub Function GetVersion(strKeyPath, strName) 'verify the component file exists Dim FSO: Set FSO = CreateObject("Scripting.FileSystemObject") If not FSO.FileExists(strKeyPath) Then GetVersion = "" Else GetVersion = FSO.getfileversion(strKeyPath) End If End Function |
