Upgrade
Posted 21 January 2005 - 18:19
and we do change it to 1.0.0.2 for the next release and upgrade doesn't work.
I do know that MSI just looks for first 3 digits, but the user's wants to stick their own version format.
My question is, Is there a way to handle this ?
Appreciate any suggestions on this.
Thanks.
Posted 22 January 2005 - 12:20
Posted 22 January 2005 - 16:47
I am trying to do Major Upgrade and I do change the Package Code, Product Code and Product Version.
Initially the Application file version will be 1.0.0.1 and for the next release we are changing it to 1.0.0.2 and the user's want the Product Version to be same as Application file version.
But as per MSI, I think it only looks for first 3 digits in the Product Version. But for us, only the fourth digit is getting changed and the installer is not treating it as an Upgrade.
The upgrade works fine, if 3rd digit in Product Version seems to have changed.
Thanks for your quick reply Stefan.
Posted 24 January 2005 - 10:51
Note that with your numbering concept you will not be able to prevent a downgrade, that is: 1.0.0.1 will happily install over 1.0.0.2.
Posted 24 January 2005 - 19:53
I am sorry, if I wasn't able to explain clearly.
I do change the ProductVersion in reference to the Application file version. These are the things I change for every release Product Code, Package Code and Product Version.
Posted 24 January 2005 - 20:01
I did attach a jpeg file, but it's not showing up...so doing a copy and paste.
Here are the contents of my Upgrade table.
UpgradeCode - (s38)
{37AAC8BC-16F9-41CA-BEE0-766BDEB66AC3}
VersionMax - (S20)
1.0.0.2
Attributes - (i4)
0
ActionProperty - (s72)
OLDPRODUCTS
Appreciate all your help.
Posted 25 January 2005 - 15:51
Posted 25 January 2005 - 18:05
If the ProductVersion is not changed, will Major Upgrade works ?
Also, will it be adding 2 icons in the Add/Remove programs if I upgrade from 1.0.0.2 to 1.0.0.3 ?
As suggested I will change the Attribute value from 0 to 512.
Stefan, please suggest me if you have any ideas on handling this scenario.
Thanks...
Posted 26 January 2005 - 04:42
Also, does that mean if we install 1.0.0.3 over 1.0.20.2 will it perform an upgrade ? If the Attribute value to set to 512 ?
Edited by cherukus, 26 January 2005 - 04:48.
Posted 26 January 2005 - 09:47
| As the 4th field is always ignored, is it like the ProductVersion is never changed ? |
| If the ProductVersion is not changed, will Major Upgrade works ? |
| Also, will it be adding 2 icons in the Add/Remove programs if I upgrade from 1.0.0.2 to 1.0.0.3 ? |
If you don't make VersionMax includsive, your upgrade entry will not match the existing version, so it will not be removed and you end up with two entries in Add/Remove Programs.
| What's the difference between having an Attribute value of 256 to 512 ? |
| Also, does that mean if we install 1.0.0.3 over 1.0.20.2 will it perform an upgrade ? If the Attribute value to set to 512 ? |
1.0.20 is higher than 1.0.0. So 1.0.20 will perform an upgrade if installed on top of 1.0.0.
Posted 27 January 2005 - 00:19
Thank you very much for your valuable inputs. Really appreciate your time.
I have one more question for you :
Can I take the 3rd & 4th digits from the ProductVersion and append them and store it in a Public property and use that Public property in the upgrade table for MaxVersion.
By doing this, will the Installer be treating as ProductVersion being updated ? (or) necessarily ProductVersion and the value in Maxversion field in the upgrade table need to match.
Do I need to write a Custom Action ? If so, at what stage I need to invoke it ?
Thanks !!!
Edited by cherukus, 27 January 2005 - 03:33.
Posted 27 January 2005 - 11:48
Windows Installer uses only the first three fields of the product version. If you include a fourth field in your product version, the installer ignores the fourth field.
