Dear Friends,
I am very new in the field of InstallShield installation tool. Please assist me from where I can start?
Also, I just wanted to know is it possible to deploy the same patch on the multiple servers from my local machine. I will have admin priviliges on all the servers. I tell you what is my situation - I am having some load balanced servers, so if I need to install any service on 1 server, it has to replicate on all the other load balanced server.
Please suggest, is it possible? One of my friend is having some knowledge of InstallShield, he was suggesting that through InstallShield, I can pull the updates and cannot push the updates to the desired servers.
Please assist as soon as possible.
Thanks.
New to InstallShield
prateekmca
, Dec 02 2010 06:51
Posted 03 December 2010 - 12:33
| I am very new in the field of InstallShield installation tool. Please assist me from where I can start? |
There's a tutorial in help, also the evaluator's guide will guide you through a sample.
If you want to patch multiple servers you need to install the patch on each server. You could do this by remotely accessing the server, or maybe using a script that runs on the server and pulls the update.
Flexera Software has such a tool called FlexNet connect which is similar to Windows Update, but it's intended to deliver updates to your customer base. I wouldn't recommend it if you need to published patches to a small number of inhouse servers.
