I have several applications which each need to install the same secondary shortcut. I have the "Replace Existing ShortCut If Found" box set to "No", which helps the situation.
In the senario that I install App #1 and it places the shortcut on the start/programs menu, then I install App #2 that has the same shortcut, everything's fine until I uninstall App #1. It will remove the shortcut, because it put it there, but App #2 is still on the machine and it should have the shortcut.
Any suggestions?
Becky
