The documented command line options for the bootstrap setup.exe that is generated by Microsoft's Visual Studio Installer do not seem to be working. Every command line option I try results in the same error dialog: "Incorrect command line parameters.". I've tried /s and /w and /v/qn but all and individually yield the same error.
Does anyone know if this bootstrapper takes command line options? If so, what's going on here?
Example command line: setup.exe /s
Bill
incorrect command line parameters
jennetta
, Jan 21 2004 15:49
Posted 21 January 2004 - 17:20
Please try the command line options of msiexec
For Eg: /f /a /x /j /L /q
For silent install try setup.exe /q
Posted 21 January 2004 - 17:26
Well, it turns out that I stumbled onto the apparent fact that this bootstapper setup.exe is just passing everything sent on the command line to msiexec. So using setup.exe /qn results in a silent run of msiexec.exe. But what about command line options for setup.exe? I was using an option of /w with a different bootstrapper that caused the setup.exe to wait until msiexec was finished installing the .msi. This enabled setup.exe to be called from an install script and to have the calling install wait until the called install was finished. Now apparently that feature is not available to me with this bootstrapper. And I cannot call msiexec directly in case windows install is not previously installed. Or am I missing something in my understanding?
Thanks for your reply.
Bill
Bill
Bill
