Directory
C:\Program Files\InstallShieldInstallationInformation\{<GUID>}
contains after installation unpackaged setup files. One of them is data1.cab file. Its size in my IS project is about 40MB. I don't need the data contained inside it because the IS project has not MAINTANANCE mode - the program installed can be removed only.
How can I reduce the size of the directory ..\{GUID} content ?
Thanks for any replay.
Directory \InstallShieldInstallationInformation\{}
Yehuda
, Dec 28 2004 17:00
Posted 31 December 2004 - 09:53
Remove is also a maintenance operation and requires these files. Data1.cab includes (among other things) your "setup support files" (which are extracted to SUPPORTDIR at install time). Maybe you have a large redistributable in there?
Posted 02 January 2005 - 12:02
Thank you for your replay.
| Remove is also a maintenance operation and requires these files. Data1.cab includes (among other things) your "setup support files" (which are extracted to SUPPORTDIR at install time). |
Yes. I understood it by trying to delete it...
| Maybe you have a large redistributable in there? |
I have to istall (when the product is being installed) many big data files, that are -saved, as you pointed above, inside Data1.cab. Those files are not needed more , when the uninstall is being executed. The question is, if there is any way to depart from my files included in the Data1.cab.
Thank you.
Yehuda
Posted 04 January 2005 - 21:02
Data1.cab only includes the engine files and the setup support files, including any InstallShield objects. Your own application files that are being install are in Data2.cab. (At least I think this is the case from the top of my head - please verify using the CAB viewer tool that comes with InstallShield)
