BUILD_01
Disk1
BUILD_02
Disk1
BUILD_XX
Disk1
etc.
Using Windows Explorer, I navigate to the Disk1 folder of the build I want to install. I double click on Setup.exe or XXX.msi and run through my UI sequence. Then halfway through the execute sequence, I have a force reboot. The system reboots but Windows Installer gets one of two errors:
"This installation package could not be opened. Contact the vendor to verify that this is a valid Windows Installer package"
or
"The system cannot read from the specified device"
This only seems to happen on certain computers. Also, if I copy the entire Disk1 directory from the CD to the computer, it seems to work fine.
What could be happening? Has anyone else experienced this?
I am using ISDev 7.02 and targetting W2K machines.
Thank you,
Joe
