I installed InstallShield 6.3 and for a test, chose to rebuild an installation that I created under Windows NT just to make sure everything was going to work okay under 2000.
The build went fine, but when I try to launch the set up or even debug it, I get a message that says;
An installation support file 'C:\program Files\Common Files\InstallShield\engine\6\Intel 32\' could not be installed.
The system cannot find the file specified.
I copied all the newly created setup files to a different Windows 2000 box and had the same problem. My original setup created under NT works okay on that box, but my setup created under Windows 2000 does not.
My installation created under Windows 2000 will not install on my box, another Windows 2000 box, or a Windows NT box. If I create the installation under NT, it installs everywhere just fine.
I see where there are issues with Windows 2000 and rights. I am a power user on my box where I create the installation and it won't install. I copied the files to another Windows 2000 box where I am administrator and it still won't install.
I saw some stuff on the Microspft page about InstallShield and DCOM and followed those instructions and still no luck with the install on any box I try.
I read on the IS forum about similar situations but not exactly ike mine and tried all the stuff suggested there -like removing the TEMP directory and all that.
So far, this installation I created under Windows 2000 will not install on any system I try - even if I am logged in as administrator on the target box.
In other words, this problem is following these new installation files around and is not local to my box or the way I am logged in.
Is there maybe something I have to set up in InstallShield when I create an installation under Windows 2000 that I did not have do do under Windows NT?
Thanks!
