I'm having problems with silent mode in InstallShield X Pro. I created a new empty project and just compile it. Then I run it with /r command to create a new setup.iss file for silent installations. It is created well.
The problem is when I run the installer with the /s command it seems to be executed but it doesn't do nothing. When I look to the log file created it says ResultCode=-3, which means "Required data not found in the Setup.iss file".
Anyone knows why it is happening and what is the solution or the data that the installer is looking for?
Thank you in advance. (Attached are the setup.iss, setup.ini and setup.log files)
Santiago
