Is it possible to change the name of the language MST files which are created together with the MSI file?
My situation: I have different MSI files that I add as support files to an InstallScript main setup project and that I launch from there. The problem is, that the MST files of the different MSIs all have the same name (e.g. 1031.MST) and so I can include only one of the MSTs as support file. Can I change the name of the MST file, so I can include all the MSTs of my MSI projects? I don't want to manually change the name of the MST files each time I build a new release.
Thanks for any hints!!!
Changing the language MST name
hrms
, Jul 16 2010 08:56
Posted 17 July 2010 - 07:06
Can't you put them in different sub-folders?
Posted 19 July 2010 - 07:42
How can I create folders in the 'Support files' section?
In my InstallShield 2010 Premier I only have the possibility to add files under the 'Support files', but no directories.
Posted 20 July 2010 - 09:06
Maybe you can use the Disk1 folder. In this case you'd have to start your setups from SRCDIR instead of SUPPORTDIR.
