My Installation has a very long sequence - when I try to access the sequence of the Dialogs in the Sequence menu - the iside.exe process receives 100% CPU and gets stuck ,
the only remedy I found so far is to manually end the process , while loosing all the unsaved changes.
anyone has an idea what else can be done ?
Win Installer 2.0.3 - Sequence halts Process
Victorz
, Jun 18 2001 07:28
Posted 18 June 2001 - 18:29
Hi Victor
I think you can include in your sequence several custom actions to report where is your installation now, for example, after your custom actions.Use Custom Action Wizard and create something like this:
Type Run VBscript code
Location Stored directly in the custom action
Enter code... MsgBox "After MyCustomAction"
In-script execution Deffered execution
Try this and you can figure the wrong place in the installation out.
Good luck!
