Is it possible to catch the StatusMessage event in a VbScript? I have the following code that is not working:
Sub BuildISXProject(sMyProject, sTarget)
Dim pProject
LogMsg "Building " & sMyProject
'This should allow for the event handler. But the event is in the release
'object, not the project.
Set pProject = WScript.CreateObject("SAAuto10.ISWiProject", "event_")
pProject.OpenProject sMyProject, True
LogMsg "Opened " & sMyProject
Dim pProdConfig
Set pProdConfig = pProject.ISWiProductConfigs.Item("Standard")
LogMsg "Set ProdConfig to Standard"
'Here, we should loop through all of the release items in Standard and build them
Dim pRelease, nReleaseCount, i
nReleaseCount = pProdConfig.ISWiReleases.Count
LogMsg "About to build " & CStr(nReleaseCount) & " releases"
for i=1 to nReleaseCount
Set pRelease = pProdConfig.ISWiReleases.Item(i)
LogMsg "About to build " & pRelease.Name
pRelease.BuildLocation=sTarget
pRelease.Build
LogMsg "There were " & CStr(pRelease.BuildErrorCount) & " errors in the build."
LogMsg "Finished building " & pRelease.Name
next
'Set pRelease = pProdConfig.ISWiReleases.Item("Standard")
'LogMsg "Set release to Standard"
'pRelease.Build
LogMsg "Built " & sMyProject & "; Config=Standard; Item=Standard"
end sub
Sub event_StatusMessage(sMessage, pbCancel)
LogMsg("Build Message: " & sMessge)
end sub
automation inteface events
dalkema
, Oct 31 2005 19:22
Posted 31 October 2005 - 21:17
OK, I have this one solved. So here it is for posterity. Add the line in red to the previously posted code to use the WScript.ConnectObject method:
for i=1 to 1
WScript.ConnectObject pRelease, "event_"
pRelease.Build
next
for i=1 to 1
pRelease.Build
next
Posted 07 November 2005 - 05:26
can you tell me what is this "LogMsg"?
Will it display the message or will it save the message in some text file?
ankur tyagi
