How do a make shure that a shortcut will be overwritten ?
I use Express v4
Suppose we have a shortcut test that points to Myapp1.exe
now i install Myapp2.exe with the same shortcut the app
is installed but the shortcut is not overwritten
wy ?
Shortcuts not overwritten
printkey
, Jan 06 2003 16:11
Posted 07 January 2003 - 09:43
If you know where the shortcut location is, and the folder structure is present in the Directory table you can use the RemoveFile Table.Give the .lnk name of the shortcut.
If the folder structure is not present in the Directory table, then you will have to use an external custom action to remove the shortcuts.
Posted 07 January 2003 - 10:05
Just to add to earlier msg, in the RemoveFile table set InstallMode to 1 so that the old shortcuts are removed on install of the msi.
