Upgrade InstallScript by basic MSI
Posted 13 January 2005 - 13:11
I have a problem when major upgrading a rpoduct installed with InstallScript MSI using a basic MSI setup. Everything works fine however there are 2 records int he "add/remove" window after the upgrade is done. I've tested it with a quite simple setup and it works just the same way:
If a product is installed with InstallScript MSI and then major upgraded via basic MSI setup there are 2 records in the "Add/Remove" window.
As far as I can see removal works(old files are removed correctly)
InstallShiled 8, service pack 2
Is there a workaround?
Thank you
Alex
Posted 14 January 2005 - 17:49
Posted 15 November 2005 - 03:13
Do you have any idea to solve this problem. Because my custom want stand-alone MSI package. They want ****.MSI file for setup program.
Dose the stand-alone package that "MSIEXEC.EXE" be generated only by Basic MSI Project?
InstallShield 10.5 Premier Edtion
BR,
Daniel
Edited by danielxu22, 15 November 2005 - 03:21.
Posted 15 November 2005 - 11:44
"Basic MSI" project can be created as a pure .msi file that doesn't need setup.exe.
Posted 17 November 2005 - 03:02
| QUOTE (ashlega @ 2005-01-13 13:11) |
| Hello, I have a problem when major upgrading a rpoduct installed with InstallScript MSI using a basic MSI setup. Everything works fine however there are 2 records int he "add/remove" window after the upgrade is done. I've tested it with a quite simple setup and it works just the same way: If a product is installed with InstallScript MSI and then major upgraded via basic MSI setup there are 2 records in the "Add/Remove" window. As far as I can see removal works(old files are removed correctly) InstallShiled 8, service pack 2 Is there a workaround? Thank you Alex |
Hi, Stefan,
Do you have any idea to solve this problem above. I fell in the same problem. Because my custom want stand-alone MSI package. They want ****.MSI file for setup program.
Posted 17 November 2005 - 22:54
Posted 18 November 2005 - 04:23
Unfortunately, our old version projects are both build in InstallScript MSI Project.
I created new project of Basic MSI Project based on InstallShield Evaluation 11 Premier Edition. And the same thing happened. It could not upgrade from InstallScript MSI Project to Basic MSI Project. There are two items in the ARP.
BR,
Daniel
Posted 18 November 2005 - 09:56
Posted 22 November 2005 - 12:14
Thanks for your help.
I think I settle this problem. I create Custom Action named FindPreVerProduct to find previous version product and remove it.
Install UI Sequence: After FindRelatedProducts
Install UI Condition: ACTIONpROPERTY
Function is here:
| function FindPreVerProduct(hMSI) STRING szActionProperty, svDest, szSubKey, szValue, szValueName, szCmd, szProgram; NUMBER nResult, nSize, nEndPos, nvSize, nvType; begin nSize = 128; nResult = MsiGetProperty(ISMSI_HANDLE, "ACTIONPROPERTY", szActionProperty, nSize); if (ERROR_SUCCESS = nResult) then nEndPos = StrFind(szActionProperty, ";"); if (nEndPos < 0) then //If ActionProperty contains only value of product codes. Copy all of the string. CopyBytes(svDest, 0, szActionProperty, 0, StrLength(szActionProperty)); else // Else copy the string before first ";". CopyBytes(svDest, 0, szActionProperty, 0, nEndPos); endif; // Silent uninstall InstallShield package // HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\[InstallShiels_]{YOUR_GUID} // Get the Value of the "UninstallString" (....\IDriver.exe /M{YOUR_GUID}) // append to that Value /uninst --> \IDriver.exe /M{YOUR_GUID} /uninst szValueName = "UninstallString"; nvType = REGDB_STRING; RegDBSetDefaultRoot(HKEY_LOCAL_MACHINE); szSubKey = "Software\\Microsoft\\Windows\\CurrentVersion\\Uninstall\\InstallShield_" + svDest; nResult = RegDBKeyExist(szSubKey); if ( nResult = 1 ) then RegDBGetKeyValueEx (szSubKey, szValueName, nvType, szValue, nvSize); nEndPos = StrFind(szValue, " "); CopyBytes(szProgram, 0, szValue, 0, nEndPos); CopyBytes(szCmd, 0, szValue, (nEndPos + 1), (StrLength(szValue) - nEndPos)); szCmd = szCmd + "/uninst"; LaunchAppAndWait(szProgram, szCmd, WAIT); endif; endif; end; |
And then, I found another problem. It is InstallScript Engine Missing.
I'm looking for any useful information about it. I've downloaded 8x/9x/10x/10.5/11 InstallShieldScriptingEngine.msm, but it always shows InstallScript Engine is Older version.
Do you have any idea to Merge ISScript.msi and Setup.msi (My installation)?
BR,
Daniel
Posted 23 November 2005 - 11:04
Merge Module of InstallScripting Engine is okay, it is funny, I reinstall my compiler (InstallShield 10.5 Premier Edtion). Rebuild the project again, and it is okay now. No idea!
Another question:
I read the article of Multi-Language MSI Packages without Setup.exe Launcher:
http://www.installsi...dlang/index.htm
And I followed setps to merge multi-language msi installation. I will get the error message of "Error applying transforms. Verify that the specified transform paths are valid".
I use Orca to modify the seutp.msi, remove "0,", save, and run the msi file. I think I miss something.
I have to use "msiexec /i product.msi TRANSFORMS=1031.mst" to setup in other language dialog.
BTW, do you know how to uninstall with maintenance dialog when I click the Remove Button in the ARP of Control Panel? I mean I want to add a maintenance dialog in the User Interface sequence of the project.
BR,
Daniel
Edited by danielxu22, 23 November 2005 - 11:08.
Posted 26 November 2005 - 11:33
The "Remove" button in ARP runs uninstall in BAsic UI mode, which means that the UI sequence is completely bypassed. You could disable the Repair buton and force uninstall through Modify -> Select Remove on MaintenanceWelcome dialog.
