SUPPORTDIR
Posted 06 June 2001 - 16:38
Posted 07 June 2001 - 00:03
All it takes is:
VBVar = Session.Property(PropertyName)
Posted 08 June 2001 - 16:23
Posted 12 June 2001 - 21:08
Then, in the first part of your script, use something like this:
Dim oArgs
Set oArgs = WScript.Arguments
With the way I wrote the command line, <Arg1> would be oArgs(0), etc.
This is a ton easier than trying to get property values from within the script, and you can use property values in the command line. The limitation would be that the command line is limited to 255 characters, and you have to double quote entries that contain white space.
Hope that helps.
